Fatmanz's avatar
Fatmanz
5th Wheel bad landing gear
Our 1993 Regal Prowler 34 ft has stripped some gears on the left landing gear, looks like everything is sealed or welded shut from the factory or earlier repairs. Would it be best to replace the whole "leg" or try to cut open and repair the existing gear?
HELP! Stan
:h
  • there should be an access cover at the top of the landing gear. if it was welded shut, maybe find a way to cut it open. angle grinder with a cut off wheel perhaps. most likely a sheared pin. a few doller in parts compared to what it would cost to replace the whole leg
  • Stan new gears and a bearing cost less than $30.00 for ours about six years ago. Ours was not welded just a few bolts to remove.
    Good luck.
