gusco01's avatar
gusco01
5th wheel tire review
I have been reading on this and other rv forums about replacement 5th wheel tires. I do not want to ever have ST tires again. The size I use is LT235-85-16 E Rated. I found information about the Bridgestone R500HD. I had 5 installed, my weight on the axles is correct for these tires. I had rig weighted when I was going on a trip with all loaded. These are commercial rated tires for work vehicles. Good tread for a trailer tire. I removed the Carlisle tires the trailer came with. Mostly because of there bad failure rate. I have spent too many times on side of interstate changing tires. Yes I have tire pressure monitor system. Anyway I think these tires are worth considering for 5th wheel use. They are poly cord sidewall with steel belts. Reports of them lasting over 100,000 miles. I'm sure they will rot out before I ever were out the tread. I could not find out where they were made before i bought. On side of tire it says made in Japan. The date code was 1120. So the tires are about 1 year old before installed. Dont like that, time will tell. I only have 150 miles on them now. My trailer weight I did not need the all steel that the heavier 5th wheels need. I hope this helped someone looking at 5th wheel tires.
