โJan-25-2017 07:18 PM
โFeb-01-2017 06:16 PM
โJan-31-2017 08:24 AM
โJan-31-2017 08:00 AM
โJan-28-2017 05:39 AM
โJan-27-2017 07:55 AM
aruba5er wrote:
The ONLY way to quit shaking is to get the tires off the ground. And them only if you don't get it too high that the lift cylinders or tubes are extended too high. Better that you get used to it and accept the fact that you are not in a stick and brick home with a solid foundation:
โJan-27-2017 07:42 AM
GoPackGo wrote:
I've been using the 6-way system for 3 years now and have discovered a few things:
1. You definitely do want to get the weight off the wheels. Fow whatever reason, I do not have a problem that way.
2. I have discovered that you need to put some large, wide supports under the jacks or they will gradually work their way down into grass, dirt, rock, gravel, etc. - basically anything that is not cement, which then allows for some 'wiggle' room, especially after a rain. I have several sets of wide plastic jack supports that I use, but I'm sure wood is fine too. I generally have 2 under each foot.
If you have a problem with #1 above, then you can follow the directions in the owner's brochure and do a manual reset that the system will remember. Just manually level it at a high enough point so that the weight is unloaded from the tires and you'll be good to go. I would not go any higher then needed - you don't want to use up any more jack travel then necessary.
Note that travel is limited with these jacks. That's why I carry several sets of plastic blocks - sometimes needed when on a really irregular surface.
I do think these things are the best thing since sliced bread. The first time you need to set up or take down in the rain, you'll be the envy of the neighborhood.
โJan-27-2017 07:03 AM
โJan-26-2017 09:17 AM
โJan-26-2017 09:06 AM
โJan-26-2017 08:50 AM
rhagfo wrote:
I don't have the leveling system, but did add JT's and all I can say is WOW!
We had a good amount of giggle even with a pin box tripod. We have been 28 days on a gravel pad a just starting to notice a bit of movement, we head out in about 5 days, may tighten tonight. They were on sale at CW online for less than $200, some of the best money spent.
โJan-26-2017 07:32 AM
โJan-26-2017 06:29 AM
kitestiff wrote:
I have lippert 6-pt system on my Chaparral 360IBL and it still shook, enough so that I installed JT Strong Arms on the front landing gear. Can't say enough how much the JT's improved comfort by almost entirely eliminating shake in the RV when people move about.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โJan-26-2017 06:26 AM
โJan-26-2017 05:42 AM
