ROADSTARJR
Nov 06, 2014Explorer
A/C unit
My A/C unit fan runs all the time now,I can hear the compressor kick on and off. Has this happen to anyone?
Campinghoss@51 wrote:
I read your problem as the compressor cycling on and off quickly. If it is doing that then in all probability it is a Freon problem. If it is cooling normally then you will need to check different components to determine the cause.
Sounds like you are low on Freon. The compressor cycling on and off is not good. If the fan is on auto it is not going to cut off until the temp is satisfied.
Halmfamily wrote:
Do you have the thermosats fan selection set to auto? If the fan is set to on it will not cycle off with the compressor. Good luck
