Fulltimeme2's avatar
Fulltimeme2
AC issues,
Hello! I have a 2003 komfort 5th wheel, I am a fulltimes in it! My issue is my AC unit makes a clicking noise and at times cycles on for a bit, then off,,, even when the wall thermostat switch is in the off position! Of which is a analog unit, not degital! I replaced that thermostat a few months ago in hoping that it may have been faulty! Nope! It’s on ac unit , and in ac cover on ceiling there’s a steel box, I hear, and even feel the clicking like it’s a relay or sensor? No idea really? I have checked all the fuses in main panel,, and 3 amp fuse in that box,, which I read about! Not even sure what that box is? In reading , it might possibly be the control box? Control box for what tho? I have picture of it, if I can insert a pic? If not it’s located under plastic cover on ceiling,,, aka AC vent! Would that box be the issue,if so can it be replaced?
Thank you, very much, whom ever has input?
Bmwman94550us@yahoo.com! It’s not allowing me to insert photo!
  • Disconnect thermostat at the unit, clicking should stop. Jumper ac thermostat input, unit should run continuously.
    If so Chris is probably right. If not the problem is in the ac or its power supply.
  • might have to call a mobil tech, ask if he services ac unit and ell him your problem.
  • If it’s a DuoTherm I would bet on a shorted thermostat cable, there’s really not a failure mode like that for the boards.
