przao's avatar
przao
Advice needed: how to keep a rig cooler...
... when it is large enough to require 50 amp service, but is only 30 amp with a single AC unit. It is really difficult to keep the inside of the rig comfortable.
We purchased a 2011 Rockwood 32-foot fiver (30 amp) that really needs a second A/C unit (however it is not wired for such). I should have become suspicious when I discovered that you needed to flip a switch between using the microwave or the electric fireplace (can't use both at the same time). Evidently, the rig is (in my opinion) over that should be sufficient for 30 amp service.
Our rig has a 12-foot super slide and we were thinking of adding mounts for an external shade to cover the broad side of the slide - when the sun hits it, the black metal frame heats so much that you can go inside and it is hot to the touch, acting like a heater. We would mount the roll-up shade when needed, and store it when not.
Bad idea?
Another thought - the A/C ducting is in the ceiling, and we notice that on a hot day, the air coming out of the registers is lukewarm. Evidently the A/C is doing nothing more than cooling the ceiling (or heating the air). Our thought is to close all the ceiling registers so all the cold air exits the ceiling unit directly into the rig. We tried it at home and it seemed to help.
Any ideas would be greatly appreciated
