Air compressor for 115 psi
5thhand
I am looking for a smaller air compressor capable of producing 115 psi. Stage 2 compressors are too big to haul around. Any ideas?
5thhand
24 REPLIES 24
time2roll
+1 for viair as you go over 80psi.
For the big dog look at oasis that will produce 200psi continuous and pull 180 amps from your battery to do it.
http://www.oasismfg.com/dc-air-compressors.html
theoldwizard1
romore wrote:
Many small compressore are capable of 115 psi but lack the volume to produce much air at that pressure. You want volume and pressure but that comes at a cost in bulk and weight. And price.
The Milwaukee M12 inflator will go to 120PSI, but it will take a long time. They also recommend running continuously for more than 10 minutes.
If you are just "topping off" tires that are down 5 or 10 psi and are not in a hurry, it might be for you.
romore
MFL
Nomad II
Nomad II
This is the one I use. It has quality fittings and gauges, and quickly goes to 165 psi. It is also light weight, about 35 lbs.
Jerry
Chainwright
TimnJo wrote:
I've heard good things about compressors from this company, a little too expensive for my budget though.
https://www.viaircorp.com/portables
Wow, $280 and up. You ain't lyin'
TimnJo
2010 Carriage Cameo 36FWS
2018 Silverado 3500HD D/A Double Cab Dually LT
pianotuna
Nomad II
Nomad II
Hi,
My single tank can "do" 115 psi--but even at 85 psi in the tires it simply doesnt work well. I'd love to have a 150 psi compressor--but it has to be small. I don't care about voltage. I do care about price.
Regards, Don
2oldman
For that kind of pressure I'd be looking at compressed air/co2/n2 tanks. Like fj says, to actually inflate a tire to 115 you'll need a lot more pressure, and more volume. Otherwise you'll be there all day.
fj12ryder
I use a small Porter-Cable also, but not the round one. I found it too bulky to store easily.
FWIW if you want a small compressor to use up to 115 psi, get one that will go to at least 135 psi. If you get one that goes to 115 psi, you'll play heck getting tires topped up to 110 psi.
Howard and Peggy
"Don't Panic"
MPI_Mallard
Had this one for years, stores neatly in my side bay,,,,click
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blรผcher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
