CoMoCo
Aug 06, 2023Explorer
Cummins12V98 wrote:Bionic Man wrote:
Why would the amount of psi effect the air bleeding out?
On my previous DRV I had the same pinbox. I was told on a DRV forum that TrailAir said to pump to 100psi and it should seal whatever was allowing the pressure to drop. I did the suggested and it did worked.
Interesting. So you are suggesting fill it to 100 psi and then drop to a lower pressure and it should hold the lower pressure? (The lower pressure being the one where the arrows line up on the shock absorper.)
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
