- texanrvrExplorerI put a Trail Air pinbox and eliminated all the chucking I had with the Mor Ryde box that came on the trailer. Love it.
- larry_barnhartExplorerIf you can see the fifth floating up and down it is working. Chevman
- B_O__PlentyExplorer II
ependydad wrote:
X3 Mine is pretty worthless.Bionic Man wrote:
dblr wrote:
Most of the ones hauling with the semi trucks install air ride hitches on the truck, like the Trailsaver, Comfort Hitch ( Air cells) or what I have is the ET Hitch especially designed for just this purpose but will warn you not cheap.
Not cheap, but probably significantly better than just a pin box with a shock. I installed the TrailAir on my 5er several years ago in an attempt to minimize chucking when towing tandem. I notice next to no difference in the way the trailer rides. I wouldn't spend the money again.
Same, I felt the TrailAir pinbox was no benefit whatsoever.
B.O. - chiefneonExplorerHowdy!
When I towed using MDT it was well known to use a air ride hitch as mentioned above to tow with a HDT or MDT. It was stated then and I believe now “ you can pay now or pay later”. Simply meaning buy the air ride hitch or pay for the structural damage to the RV later. Some people actually use a air ride hitch and air ride pin box.
“Happy Trails”
Chiefneon - stripitExplorerWhen I had a International MDT pulling a Mobile Suites 17,000 lb trailer I ran a Trailer Saver Hitch and loved it, made a huge difference in ride for the trailer and the truck. I do believe the hitch will bolt right up for you.
- ependydadExplorer
Same, I felt the TrailAir pinbox was no benefit whatsoever. - larry_barnhartExplorerWhen we tow and the alpenlite is floating up and down it is a no brainier to understand what that means. Air hitch since 2001. Chevman
- Bionic_ManExplorer
Not cheap, but probably significantly better than just a pin box with a shock. I installed the TrailAir on my 5er several years ago in an attempt to minimize chucking when towing tandem. I notice next to no difference in the way the trailer rides. I wouldn't spend the money again. - dblrExplorerMost of the ones hauling with the semi trucks install air ride hitches on the truck, like the Trailsaver, Comfort Hitch ( Air cells) or what I have is the ET Hitch especially designed for just this purpose but will warn you not cheap.
- azdryheatExplorerIt should. I've seen many semi's towing large 5th wheels.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
