Jan-21-2016 12:40 PM
Jan-23-2016 05:46 PM
gmcsmoke wrote:
Grand design claim they are extended stay approved yet have a 54 gallon fresh water tank?
no thanks but this along with several other items and you can hardly say they are setting new standards.
playing catch up more like it
Jan-23-2016 04:03 PM
Jan-23-2016 03:37 PM
Jan-23-2016 01:04 PM
Jan-23-2016 11:44 AM
Jan-23-2016 11:31 AM
Jan-23-2016 10:46 AM
wing_zealot wrote:topjimmy wrote:I guarantee that I can design you a 6-inch I Beam that is just as strong (or stronger) than your 12-inch. And can then therefore add 6-inches of interior height. Point being, 12" vs. 10" may mean nothing, and you would have no idea of the differences between the two. I can just simply change the yield strength and make all the difference world.
My friend is camping right next to me as I type this and we just measured his 2014 369RL rear I beam and it is a 10 inch I beam (just so you know) I know the Momentum toy hauler has the 12in main frame maybee the 2015's Solitudes have a 12inch and that would be an improvementDave&Jeanette wrote:
Just so you know the Solitude main frames are 12 inch.
Jan-23-2016 05:40 AM
Jan-22-2016 04:33 PM
I’ve spoken to several of the Grand Design folks from engineering, product management and marketing and one thing is for sure, Grand Design is totally committed to complete and total customer satisfaction (I believe this is certainly a part of that “Setting New Standards in the RV industry”……), and I feel a lot better now. I’m a bit blown away!!
Seems GD has certainly considered aluminum roof trusses in the past but have realized the overall benefits of wood trusses falls closer in line with the company’s overall commitment to product quality. And after discussing with these gentlemen and doing a bit more reading myself, I now totally agree!
Why doesn't NuWa use an all aluminum structure like popular Indiana manufacturers?
NuWa made the decision to begin the use of aluminum structure based on marketing and the fact that many people were concluding that an "aluminum caged" product was superior in construction technology, weight and strength. Our 40+ years of experience as a leader in 5th wheel design suggests that may be "flawed" information. We have proven that wood construction need be no heavier or less strong than aluminum construction, that is built properly. We now build both materials, and are comfortable doing either, however our opinion is still that wood construction provides a superior product, and today we use both in the construction of our trailers. The strength of the NuWa trailer is actually created by the superior and light weight Blue Dow foam lamination concept.
NuWa uses an aluminum substructure in the sidewalls and ends of the coach only. No aluminum in the floors or attics, where metal promotes conduction of cold and moisture resulting in condensation.
90% of the walls are Blue Dow Structural Foam, rather than wood or aluminum. This creates a superior insulation and the only product with a guaranteed sidewall R Factor. (Water absorption in standard white foam reduces R Factor over time, and the use of Blue Dow Structural Foam eliminates this problem.)
NuWa's aluminum substructure sidewall is actually a "hybrid" wall, as we core fill the aluminum with wood in those areas where additional strength is required, because aluminum will not hold a screw. Not so with the lower priced brands. With NuWa's combined use of wood and aluminum substructure, you get a superior product because of NuWa's unique Blue Dow foam vacu-bond process, which makes the sidewalls virtually resistant to water penetration.
Jan-22-2016 03:00 PM
Jan-22-2016 02:30 PM
Jan-22-2016 01:46 PM
Jan-22-2016 01:02 PM
Jan-22-2016 12:00 PM
