przao's avatar
przao
An adventure in remodeling
We are a bit disappointed in the quality of our 2011 Rockwood fiver. We should have known better (have been RV-ing for 20 years) and done more homework, but my wife fell in love with the rig and we impulse purchased.
Then came the problems:
  • Cheap blinds (the day/night kind, you know what I mean). Rockwood didn't even install the typical metal top clips - just turned the top rail 90 degrees and screwed it into the wall. So far, two years of RV-ing and three of the blinds have broken strings (a screw actually went through one of them)
  • It should have been a 50-amp rig: microwave and fireplace can't be used at the same time - they put in a foot switch near the door that we did not notice. You can use either, but not both.
  • Woefully underpowered A/C
We went to Bretz RV in Missoula wanting to trade in, but they would only give us only about 1/3 of what we paid. Our solution: upgrade the cheap parts to quality, and at the same time make it more comfortable, and tailored to our needs.
Regarding the blinds: Our home has fantastic cellular blinds - we're planning to replace all the RV blinds with the quality ones
Fireplace/microwave/A/C problems : Move the existing 13.5K BTU A/C unit to the rear of the coach and bring in a separate 20 amp circuit. Add the fireplace to that and do away with the foot switch. We'll not likely use the fireplace at the same time as the A/C unit so all should be good to go. Then install a 15K BTU heat pump in to the original A/C spot
Not a quality issue, but will make it more comfrtable: Take out the existing couch/sleeper and replace it with residential recliners (or theater seating) and get rid of the existing small uncomfortable recliners. Overall will save weight, give us more room, and definitely more comfort.
We're heading in to winter, so these projects will need to wait until spring, but we're excited to turn our lemon into lemonade.
  • Sounds like you have a good project list yourself. As to the large parts, I'm going to try to take items apart, but if that fails, I'll haul everything to our local RV place and have them take out the small slide for furniture replacement.
  • our project list:
    remove pull out couch, replace with theater seating but unsure how to get it through the door
    make the old CRT TV hole in the front room into a closet, with a hinged wall with the new LCD tv built into the moving wall, add electric fireplace below TV but unsure how much heat will be transferred upwards to the TV,
    removed dinette booth and replaced with an office area, filing cab., printer, office chair
    replaced bed with a much nicer one that only we have slept on
    removed upper loft bed and turned that into a storage area
    need to add second AC in bedroom and fish the wire back to the panel
    keep us posted with your projects thanks
