Sort By
- transamz9Explorer
avvidclif1 wrote:
I have an auto-level system. Whichever way the trailer would roll on it's own determines where I put 2 chocks (on the downhill side of 2 tires, one on each side). I then put the TV in neutral and let the trailer settle against the chocks, that takes any load off the front landing gear when unhooking. Once unhooked I auto-level. If the tires are not touching the chocks, OK, the trailer is supported by 6 jacks. When getting ready to hook back up I raise the back jacks and return the front to the disconnect position. The chocks will now be in touch with the tires and keeping it from rolling downhill as I hook up.
Does your auto level not have the return to hitch feature? When I get ready to hook back up I just push the right and left arrows at the same time and it puts it back exactly where I unhooked from. The only difference is that all 6 pads stay on the ground until I auto up everything. I like that all 6 pads are still on the ground until I'm hooked up. - drfifeExplorerI use pair of rubber wheel chocks from Harbor Freight. I have the big yellow plastic chocks, these are better:
Rubber Wheel Chock with Eyebolt - Mile_HighExplorerOh here we go again on whether the system is designed to level with the wheels off the ground :)
I'll be honest, I gave away my rotochoks and my leveling boards and I carry some stackable pads and yellow wheel chocks. Wheel chocks rarely if ever come out of storage. stackable pads come out when my leveling calls for wheels "up" :) - avvidclif1ExplorerI have an auto-level system. Whichever way the trailer would roll on it's own determines where I put 2 chocks (on the downhill side of 2 tires, one on each side). I then put the TV in neutral and let the trailer settle against the chocks, that takes any load off the front landing gear when unhooking. Once unhooked I auto-level. If the tires are not touching the chocks, OK, the trailer is supported by 6 jacks. When getting ready to hook back up I raise the back jacks and return the front to the disconnect position. The chocks will now be in touch with the tires and keeping it from rolling downhill as I hook up.
- kohaiExplorerx-chocks between the tires are for stability. Their instructions say to add them AFTER you have leveled.
I use both regular chocks behind last axle and in front of first axle. Then I unhook (the trailer does move so I need those chocks there). Then we level. Then x-chocks if we're going to use them. I also have Steadyfast on my trailer.
There are times when I hook back up to the truck that one of the chocks is wedged under the tire. I have to pull forward a tad or backward to release pressure on it to loosen enough for my kid or wife to remove it.
I have to be pretty level before I use the self leveling system. The system is not designed for the wheels to be off the ground -- it needs the wheels to take some of the weight. Therefore, I use us the Andersen Camper Leveler to get the trailer almost level. These are easy to use and fast. - transamz9Explorer
Cdash wrote:
Correct me if I'm wrong, but if you placed regular old wheel chocks in front and behind the wheels, then auto level the rig, wouldn't it potentially loosen up the chocks as load is removed (potentially) from the wheels?
Then if you snugged them up after auto leveling, then got ready to leave, the chocks would be hopelessly jammed in place?
Just asking. Haven't been out with our New camper yet that has auto leveling.
I set my wedges before I unhook and never touch them again until I hook back up. Once the six point system is on the ground it ain't going anywhere. When I return my 5er back to hook-up position the chocks are right where I put them. - I place my wheel chocks - in front of the front axle , and behind the rear axle.... That eliminates the chances of mashing together . .
- shepstoneExplorer
Readjust after or as it levels up if needed, You may have to nudge the rig forward and or back to get them out if they get to tight when its back down, you will want to do a pull test before removing them anyway. - Mile_HighExplorerThat was my fear.
- CdashExplorerCorrect me if I'm wrong, but if you placed regular old wheel chocks in front and behind the wheels, then auto level the rig, wouldn't it potentially loosen up the chocks as load is removed (potentially) from the wheels?
About Fifth Wheel Group
19,011 PostsLatest Activity: Apr 26, 2025
