transamz9
Mar 16, 2016Explorer
avvidclif1 wrote:
I have an auto-level system. Whichever way the trailer would roll on it's own determines where I put 2 chocks (on the downhill side of 2 tires, one on each side). I then put the TV in neutral and let the trailer settle against the chocks, that takes any load off the front landing gear when unhooking. Once unhooked I auto-level. If the tires are not touching the chocks, OK, the trailer is supported by 6 jacks. When getting ready to hook back up I raise the back jacks and return the front to the disconnect position. The chocks will now be in touch with the tires and keeping it from rolling downhill as I hook up.
Does your auto level not have the return to hitch feature? When I get ready to hook back up I just push the right and left arrows at the same time and it puts it back exactly where I unhooked from. The only difference is that all 6 pads stay on the ground until I auto up everything. I like that all 6 pads are still on the ground until I'm hooked up.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
