- BarneySExplorer III
dedmiston wrote:
My Opinion: The guy who bumped the thread is a spammer.
I agree. Thread closed. - mooky_stinksExplorerAnother vote for Lucas Red N Tacky. I grease bearings every other year and it’s been the only one that looks like it did when I packed it last. Truth be told, I’ve never had a bearing failure or seal leak even with the grease that is “liquified” after 2 years.
- NamMedevac_70Explorer IIFor many years I have had excellent results with synthetic grease with no drooling, dripping, leaking, squirting, etc. Worth the small extra cost to me. YEP
- dedmistonModerator
cummins2014 wrote:
FarrissE wrote:
The best RV wheel-bearing grease that I found is Plews & Edelmann LMX. It is really convenient and easy to use. It is soft enough to be applied to bearings. It does not drip easily, so it will linger where it has been applied. In addition, this grease has anti-corrosion properties that help prevent the gradual deterioration of my bearings. This is very convenient because I won't have to think about getting a replacement soon. This grease is insoluble in water, so there are times when my RV wheels are wet due to road conditions during the rainy and winter seasons. I’m always confident that the bearings are well lubricated.
This thread is pretty old ,the OP asked about Red N Tacky, some seem to be having heartburn with synthetics , I have used both Mobile 1 ,and Red N Tacky ,both have performed well.
My Opinion: The guy who bumped the thread is a spammer. - JIMNLINExplorer III
Likes to tow wrote:
How is Lucas Red N Tacky for wheel bearings?? The specs say the drop point is 540 degrees and this is above Dexters recommended range. Anyone know of a better type??
Lucas red and tacky works great for my use.
With five trailers (5.2k/6k/7k/8k axles) running on 28 hubs/tires/wheels anywhere from 60k-80k miles a year per trailer the the red and tacky never gave us any grief. However these trailers never sat like most rv trailers for any length of time.
I still use Lucas products and red and tacky goes in every thing on the place that has bearings.
Lots of good bearing grease brands out here. - cummins2014Explorer
MFL wrote:
cummin2014:
Well yes, of course marketing plays a roll. I know that Ford does not manufacture Motorcraft oil, or filters, and Yamaha, and Polaris do not make their own oil, or grease. I do think these items are made to meet the standards of the company they are supplying.
I would have to think, that Timken is going to protect their reputation, when putting their name on a wheel bearing grease.
I don't think that a manufacturer can deny a warranty claim, if their name brand fluids are not used. If a proven inferior product was used, maybe??
I consider garyp4951 a standup knowledgeable guy, and he says the Timkin grease will not leak or drip (possibly separate), suggests good quality. FTG, is also knowledgeable, and uses this product, knowing Timkin would not put their name on an inferior product.
While two products, side by side, could be same (??), I'd be willing to pay a little more for one that is branded Timkin, Motorcraft, Yamaha, Honda, etc.
I know "a fool and their money, are soon parted" but I think I'll still be alright, at the end of the day.
Jerry
I have a feeling you will be just fine . :) - I am by NO MEANS a grease guru, but I did slept a Holiday Inn Express last night :B
seriously, The only reason I use Timken is because the local truck repair guru's I know said they use it, and its good quality... AND . . I ASSUME someone with a reputation of Timken will not put their name on just any grease.. they have standards...
Been using it for many years trouble free.... like stated above, I think it is more important to have the bearings greased properly, then it is to have better grease... - MFLNomad IIcummin2014:
Jerry - cummins2014Explorer
MFL wrote:
Timken premium grease...a wise choice guys!!
While there are likely many good choices, an all purpose grease, is not something I'd use for severe application, just because it was in the gun.
I have 3 different lever guns, and a pistol gun, each with a quality grease, made for the intended use. Even my snowmobile suspensions, are greased with a purpose designed product for extreme low temp, and is waterproof/corrosion proof.
I hear people sometimes mention "a waste of grease"...really? In the grand scheme of things, cost of RVs, toys, etc, does cost/amount of grease matter?
Jerry
Jerry ,do you think we buy into marketing a bit on oils ,and grease , just saying.:B - cummins2014Explorer
frizfreleng wrote:
laknox wrote:
My dad's usual response was "whatever's in the grease gun". :-)Lyle
After 60 years of putzing around with vehicles I will have to agree. By the way, Timken makes bearings and **** good bearings. They are not in the petroleum/lubricant business. Putting their name i=on a petroleum product sounds like marketing. I suspect their grease is no different from most any other.
I would agree, not quite 60, but 50 plus years I have been dealing with bearings, the important thing is that the bearing is pre loaded , and packed correctly . Then tightened with the correct pressure . I couldn't tell you how many different brands of grease I have used in that 50 years on bearings ,and have yet to have a bearing failure.
I do get a kick out of some of the replies here, but the last few years , the two brands as said I have used is synthetic . Mobile 1 ,and the Red N Tacky. Haven't seen any oozing . ;)
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
