- Lar_sExplorerRVparky shows low clearance when looking at maps.
- laknoxNomadLowclearances.com is back up and running as of 0830 AZ time, 4-20-20.
Lyle - Pine_BarrenExplorerI have park advisor and yes it does show the rest stops and stuff. I wasn’t aware that it did low clearance. I can’t figure out how to put in for trip planning on it.
- VeebyesExplorer IIIf you see semis going in the opposite direction you are good too.
- laknoxNomad
justme wrote:
search for lowclearancebridgeinfo..pdf then select: https://member.coach-net.com/members/pdfs/LowClearanceBridgeInfo.pdf
Thanks, but nowhere close to the 8,000+ POI d.b. of Route-1. Just sayin'...
Lyle - justmeExplorersearch for lowclearancebridgeinfo..pdf then select: https://member.coach-net.com/members/pdfs/LowClearanceBridgeInfo.pdf
- laknoxNomadFound on another forum that lowclearances.com went down in early March, came back up, and is now down again. Would love to contact the host and see what's going on.
Lyle - one_strange_texExplorerIt is interesting to note that a dataset of low clearances was available some time back on a handy site I use called "POI Factory," a free site which is a repository of free lists of points of interest. As I interpret what I read, the low clearance POI data was taken down at the request (or demand) of the owner of the data since it was considered copyrighted information. I do not know if the data came from lowclearances.com or if that was the data owner in question.
Maybe the lowclearances.com site or the information itself will return at some point.
To be most useful, the data needs to be refreshed and kept up to date.
Also note that, in addition to the Garmin resource I mentioned in my earlier post, an app on Apple devices named "ParkAdvisor" contains low clearances on its maps in addition to RV parks (including individual park information), fuel stops for RV's and major outlets like Walmart. Other similar apps may have the information as well. I do not know how up-to-date the information is. I know Garmin issues map updates around 2 times a year but I cannot verify if low clearance information is updated with the same frequency. - laknoxNomadD@mn. Lowclearances was online just last week. Their d.b., Route-1, lists over 8000 low clearance points. Compatible with all major maps and GPS. I was =this= close to buying it, then!
Lyle - Pine_BarrenExplorerThank you for the replies I found a app called truckers map it has things for clearance as well as location of truck stops. May try that one out also.
About Fifth Wheel Group
19,010 PostsLatest Activity: Apr 07, 2025
