jyh818
Feb 25, 2019Explorer
California Non-Commercial Class A License
I am not sure if this topic was covered in the past so forgive me if I'm asking again.
I understand that to tow heavy for recreational vehicles up to combined weight of 26K lbs. in CA, you will need to get a non-commercial class A license.
The question I have is that 26K lbs. Is that the combined GVWR of the truck AND the GVWR of the 5th wheel?
Example: I have a 2006 F350 dually 2WD crew cab, long bed with 4.30 gear diesel. GCVWR is 26K lbs. Truck loaded with people and gear (no 5th wheel hooked up) is 7,500 lbs. GVWR of the truck is 13k lbs. If I get a 5th wheel with a GVWR of 16K lbs., even if I fully loaded the 5th wheel, my combined would be 23.5K lbs., under the 26K lbs. combined.
Is it still legal? If you take the GVWR of both truck and 5th wheel, it will be over 26K lbs. (13K truck + 16K 5th wheel) at 29K lbs.?
I'm not sure if the 26K from a legal standpoint is the addition of the weight ratings or what you really have.
Thanks.
Thanks.
