wvcampers
Apr 25, 2014Explorer
After replacing the second regulator, the red one, twice I eliminated it. The reason for the second regulator is because you have a rubber hose running between the tanks through the front storage area. If you replace the rubber hose with hard pipe the red regulator can be taken out. Another problem is the hose that connects to the tanks. They have a check valve in them that will prevent flow. The first thing that I would check is the hose at the tank. I took mine off and found it to be plugged.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
