Jul-09-2013 11:01 AM
Sep-04-2013 08:57 AM
Sep-04-2013 08:32 AM
smkettner wrote:driveandfish wrote:
So how to remove it? Support the trailer and axle, remove the nut and pound it out? Is there a bushing in there that I would damage?
Yes, just give some support on the hanger opposite side of the pounding. There is a bushing but you will not damage it for pushing the bolt out. Bushing should have an interference fit to the spring eye and may need a drift punch to push it out. If you have a new bushing you can use a press to push the new in and the old out at the same time. I used a large C-clamp to push the new bushing in.
Sep-03-2013 10:47 PM
Sep-03-2013 09:54 PM
Sep-03-2013 09:24 PM
Sep-03-2013 07:36 AM
driveandfish wrote:
Not to hijack this but I am still having the same problem. I have gotten grease in all the bolts except one. I have tried with it jacked up and on the ground and many positions in between. One bolt will not take grease. This is the first time I have greased these. I am not sure what the previous owner did. Can I pull the zirk and clean the bore somehow?
Sep-02-2013 07:14 PM
Sep-02-2013 07:08 PM
Jul-09-2013 08:11 PM
Jul-09-2013 06:13 PM
Jul-09-2013 06:09 PM
Jul-09-2013 11:47 AM
Jul-09-2013 11:44 AM
Jul-09-2013 11:41 AM
