N-Trouble's avatar
N-Trouble
Can't get grease into shackle bolts
I was going around doing my annual greasing of my shackle bolts on my 2004 Weekend Warrior and found that a couple of the bolts I was unable to pump grease into the zerks. I assumed the zerks were stuck shut and decided to replace them. After replacing the zerks there is no change and I am still unable to pump grease into the bolts.
On the bolts I am able to get grease int,o any excess grease as I am pumping comes out between the shackle and bushing on each side. On the bolts I am still having problems getting grease into I am going to now assume they are either plugged or the bolt is simply overtightened not allowing anything (grease or air) to escape as I am trying to pump grease into them.
Anyone ever run into this problem? DO I simply need to loosen the bolts?
