Diesel_Camper's avatar
Jan 19, 2015
Ceiling repair after collision...
I'm looking for advice on fixing these gouges and scratches in our ceiling. These were caused by a collision that pushed the interior wall panels into the ceiling which has a slight sag due to preexisting water damage. The leaks were fixed and the ceiling panels were otherwise unblemished so we decided to live with the sag. I'm hesitant to just spackle it and the shop that fixed the collision damage didn't want to touch it unless we authorized a full replacement of the panel (which we didn't). They gave me some ceiling tape I could stick over it, but I was hoping for some suggestions that might blend a little better...
  • You might try just spraying it with some Kilz. It might blend the area nicely.
  • I'd tape and knock-down or orange peel texture it just like a home ceiling. Most RV ceilings can be done with two to three cans of texture material
    Knock Down Ceiling Texture
    Tape up all seams with drywall tape. Fill in holes with spray foam, sand flat and cover with drywall tape. Spray on the ceiling texture. Let sit for 15 minutes. Run a rubber squeegee over it. Let dry, then paint to the color of your choice.
