I am new to driving a fifth wheel, but not new to towing. I just got a 98 31' sea breeze fifth wheel. I am using a 15k Reese hitch with kwik sliders. Any time I accelerate from a stop, there is a loud and noticeable "clunking" sound that comes from the trailer. I used the search function, but couldn't find anything. Does anyone know what might cause this and if it is a real problem or not.
The clunk is the play between the pins that hold the hitch to the rails and the hitch. When I had my 5'er mine did it from day 1, Reese and the place that installed it said it was normal.
2007 Fleetwood Excursion 40E Cat C7 350 HP 2007 Chev 2500HD D/A Long bed CC (Yes, it is my TOAD :B) 2011 Toyota Tundra 2013 Jeep Wrangler Unlimited Sahara (Backup towed) Gone but not forgotten, 2008 Jayco 299 RLS
We are saying you might have play in the hitch head. Depending on brand of hitch there may or may not be an adjustment. Mine has a hex bolt on the front of the head, that I can adjust to remove the slop between the hitch and the trailer pin.
Does it "clunk" as you are applying your brakes to stop and then again when you start moving? That would indicate that there is play some wheres in your hitch.
Sorry if this is a stupid question, but what do you mean loose hitch? It locks into the rails tightly and doesn't seem to have any play. Is there anywhere else I should check? That is the only place it contacts the truck.
