bshgto1 wrote:
Of course not telling anyone what to do. But have you seen the amount of rust in your tank after about a year. Your trucks primary fuel filter will get most of it 10 micron but you should change it once a year ,your secondary filter 4 micron will also become really dirty if you let the primary go to long. This is like running sand through your injectors not a good thing for longevity.
I put this motor cycle filter in line and in half a tank it was mostly clogged with rusticals ( think Titanic) when it ran out to mostly empty it was clogged so no fuel would run. Just a thought.
After I saw that I went ahead and bought a little fuel pump connected it to one of the uplifter switches and installed a large Goldenrod transfer tank fuel filter at 10 Micron to catch it all before it gets into the trucks tank and fuel system.
There suppose to be a pic of the little fuel filter starting to clog up with rust after about 17 gals. The tank is 8 months old.
I've had my tank since I bought my truck in 2011. No rust in it.
