Designer 35RLTS and Jayco Talk...Thanks Frank!!
sanderson_66
Since there does not currently seem to be a Jayco owners forum, Moderator Frank has graciously allowed this thread. It will be for discussing Jayco related questions and comments. Anything not Jayco related will be deleted. Sounds more than fair to me. Thank-you Frank!
2007 Dodge Ram 3500 Laramie, CTD 6.7, 6 speed auto,DRW,QC,LB,4X4
2008 Jayco Designer 35RLTS
1,450 REPLIES 1,450
loydt
On the thermal pane windows, anybody else notice they leak? Just about every one of mine does. The felt track on the inside is wet after a good rain.
2021 Jayco Seismic 4212 (on order)
2021 Jayco White Hawk 32BH
2018 Ram 3500 DRW 4x4 CC Cummins/Aisin Laramie Longhorn
loydt
If anybody wants to know how they can watch different programs on the bedroom and the main TV with satellite, let me know. I found an easy way to do it. You will need to have two receivers, though.
M_GO_BLUE1
I have thought about an inverter but need to solve two questions first: (1) where to put the inverter? (especially with the front compartment being taken up by the genny); and, (2) where to install 2 additional batteries (giving me a battery bank of 4) as I believe using an inverter on only 2 batteries would not be practical...
The ultimate solution would be to figure out where I can store four 6V batteries in the Designer...the 2 existing battery trays are too small for a 6V battery
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
Travlingman
We use the "Dish" network and take our dish with us alot. Take a receiver from the house. Real easy to set up. I just run the cable from outlet behind the DVD player to satellite receiver, then use a satellite signal finder to set up, and then use a "S" cable to run into side of TV. This way we can switch between satellite and regular TV to watch locals of area we are in. I have saw that Direct is running a deal where they will give you an extra dish, tripod and cable for your rig. Saw the promo in a Trailer Life I think.
2017 F-350 King Ranch DRW
2014 Landmark Savannah(sold)
2022 DRV Mobile Suite 40KSSB4
eaherrmann
DirecTV uses the dish outside and a receiver box inside. Jayco has run 2 different satellite cables that are labeled inside the dvd cabinet area. 1 is labeled upper satellite if you have a roof mounted dish, the other is labeled lower if you use the side satellite input. I hope to get an inverter to run just the entertainment equipment during the evening.
Ed & Elizabeth
Copper
2007 Dodge Ram 3500,QC,LB,DRW,4x4 w/6.7 CTD (BlueTec), 6 speed auto, Factory Exhaust Brake
B&W companion hitch over sprayed in liner
2008 Jayco Designer 35RLTS, Onan 5500, Polar Barrier
Army/Navy retired
M_GO_BLUE1
The genny just running normally is supposed to burn gas as follows:
normal 0.3 gallons/hour
1/2 load 0.6 gallons/hour
full load 0.9 gallons/hour
We have already put 14 hours on the genny and does great...there is a lag time of about 10-15 seconds after you turn on the genny for electricity to the trailer (watch the microwave to see when it pops on)...just changed the oil this pas weekend (supposed to change after the first 20 hours)
So you just plug the dish/tripod into the outside and you get all those channels? Anything to do on the inside after you plug in outside? What exactly is upper satellite and lower satellite?
We do alot of boondocking so on those nights when we want something to do or late at night I'm thinking why not just turn on the genny and the Direct TV and make a night of it
eaherrmann
Hey Cruz, you hit the nail on the head, it is a "welcome" mat.:C
Eric, you think the outside ("my area") is color coordinated you should see the inside.
Our satellite setup is DirecTV. The dish and tripod is sold as their "emergency" setup. You can also get them on Ebay pretty cheap. We have DirecTV at our residence and we simply grab a receiver on the way out the door. Point it south and with a little "aiming" practice you get 800+ digital channels. The REAL nice thing is that Jayco added an outside satellite plug in the back that attaches directly to an input port inside by the antenna port. They are all labeled, upper satellite, lower satellite, cable....
The DW and I are going dry camping over Memorial Day to test our current setup. I'm guessing we'll do alright with the genny and second battery. Any idea on how long a tank of gas will last (without A/C)?
Ed & Elizabeth
Copper
Army/Navy retired
M_GO_BLUE1
CHV,
Make sure you answer Loyd quickly...I'd hate to see a grown man whine again! ๐Ÿ™‚
eaherrmann,
Nice set up!
I'm interested in the dish setup you have outside. What service is that and what would entail ourselves getting something like that since we tend to boondock alot?
cruz
Nice Set up ... Kinda looks alot like ours !? :h
Also looks like you have the same stair tread covers we do ... with the bottom one being the "WELCOME" mat ??
CRUZ
HR & Beth
2006 Chevy Silverado LT3 3500HD, DRW, D/A, CC, LB, 4x4 and RED
Cassie - pure Black Giant Schnauzer
Mollie - pure White Mini Schnauzer (the boss)
CHV_FRK
Look in my message above... I need your e-mail address. PM me.
Dana and Natalie
2018 Chevy Silverado 3500HD High Country DRW CC LB 4x4
-60 Aux Tank/Toolbox, Line-X, Full Tint, AirSafe 25K Hitch
2018 Jayco Seismic 4113, 45'7", 17,800lbs w/o the Toys.
loydt
CHV, I never got your email?
CHV_FRK
Wow, it looks like you are really set up. Dish, name on a sign, tikis, and your own trash can. That is relaxed.
I see you even have coordinating brown tread covers on the stairs! A+
Dana and Natalie
eaherrmann
Well our maiden voyage went without one single problem (due largely to y'alls experiences and feed back)Some thing we did find, those wonderful flaps over the slides sure are noisy. We found a suggestion in another forum that explains the use of a rope and bungee cord, we may try that. All in all, the trailer pulls like it's not even there and the truck impressed me like no other. There's a sad side though...we're not going to be able to update our adventures as often as we'd like....it's going to be a challenge if we're out camping as often as were likely going to be.:B
Happy Camping!!
Ed & Elizabeth
Copper
Army/Navy retired
CHV_FRK
loydt... I e-mailed you from the forum, but hadn't heard back. If you could PM me with your e-mail and I'll send you the pics I took over the weekend.
Dana and Natalie
M_GO_BLUE1
Loyd...it's cold enough here that snow is a definite possibility today!
