gdweb's avatar
gdweb
disc brakes
For those who have done this, does your Actuator make alot of noise when engaged? (titan brakerite system) finished my install yesterday and it seems to be pretty loud. Is that normal?
  • The Titan pump is noisy right next to it. But behind a compartment door, from a few feet away it sounds just a little worse than a water pump running.
  • I can hear it from the driver's seat in the truck (CC long bed) if the windows are down and the AC is off. It's not terrible, but I've never stuck my head in the front compartment with someone stepping on the brakes.
    Rob
  • If you are LOOKING at it yes they are noisy. Behind a compartment door not so much!
    Keep an eye on your brake fluid level. It will get down there in a hurry. I also recommend re bleeding after the first tow.
