Gooseroller's avatar
Gooseroller
Dometic dm2852 help
I have a 2014 Montana fifth wheel with a dometic 2 way fridge that won't cool. Everything seems to work, lights inside and power and check indicator lights but no cooling. I have tried on both ac and gas and still no cooling. I can hear the gas burning so I don't know what else it could be. I put it away in October and it was working and pulled it to Texas, got here and not working, any ideas?
  • See as you have lights and can turn it ON but fridge doesn't cool down on electric or propane then it is a 'common' component (one used by both heat sources) and not a item specific to one or the other.
    That narrows it down to:
    *Ventilation/air flow issues........backside of fridge has something blocking the natural draft from lower vent to upper vent (remove lower access vent cover and look for obstructions-fallen insulation etc)
    *Leveling.......if off level the gravity flow of coolant will be interrupted causing cooling issues (and permanent damage)
    *Thermistor.....temp sensor located in food section in a clip on far right fin. The thermostat uses the thermistor to control cooling cycles. Bad thermistor no cooling. Take thermistor out of clip and let it hang down into lower area of food compartment. Turn fridge ON----after 8 hrs. freezer should be frozen (0*F or lower) and fins in food compartment should be 2*F or lower. IF not thermistor could be bad IF cooling unit is NOT plugged.
    *Cooling Unit......could be plugged/obstruction in perk tube or evap tubing. Plugging is caused by off level operation which causes overheating of sodium chromate which crystallizes and plates out on tubing. This damage is accumulative and permanent.
    Or cooling unit has cracked and hydrogen gas has leaked out, ammonia has leaked out and the sodium chromate has leaked ou(it will leave a yellowish residue usually down around burner area)
    To test cooling unit (if no leaks)
    Disconnect electric heat element leads from control module...plug leads into an good AC outlet and run fridge for 8 hrs. No cooling them cooling unit is plugged......done /dead/no good.
    Hopefully it is just something fallen down blocking off the draft or the thermistor is bad.
  • I had the same problem and the electric element was out.
    I agree with going to rvrefrigeration.com and check out their Youtube channel. I made a jumper wire for the electric element and plugged directly in the 110v power (their YouTube channel). There was my problem.
    www.rvrefrigeration.com
    I had to pull my refrigerator to replace the element.
    Good luck!
    Pat
  • It seems to early for a 2014 refrigerator for the tubing to leak but you never can tell. It should be cooling if the gas is heating the boiler unless there is a leak in the tubing. You want to check if there is any yellow powder in the back of the fridge which would indicate a leak.
  • Could be a fuse on the control board. Go to rv refrigeration.com and checkout RV owners info.
