Impulse24
Oct 28, 2017Explorer
So the newer GM duallies have LT235/80R17E tires, which at 65 psi are rated to 2680 each. The front GAWR appears to be 5600 pounds. So at 65 pounds inflation the tires are unrated for the max axle rating. So are you sure it says 65 pounds all the way around.
BTW at 35 pounds dual the tire is rated at 1570 each or a total of 6280, which is fine for casual everyday used include runs to box stores giving well over a ton of capacity in the bed.
Chris
Chris, I just noticed your post and you deserve a response,
So here it is from the horses mouth as they say..
Tire Size: LT235/80R17
Tire uses LT-Metric tire size standard, with tread width of 235 mm or 9.25", aspect ratio of 80%, sidewall height of 188 mm or 7.4", and rim diameter of 17" or 431.8 mm.
Tire Load Index: 120
Tire has a load index of 120, with maximum load carrying capacity of 3086 pounds or 1400 kilograms per each tire.
Tire Speed Rating: R
Tire has a speed rating of R that allows for maximum service speed of 106 miles or 170 kilometers per hour.
Maximum Tire Pressure: 80 psi / 5.52 bar
Tire has a maximum tire inflation pressure of 80 psi or 5.52 bar per tire as set by tire manufacturer.
Always use the correct tire inflation pressure recommended by the vehicle manufacturer, or as stamped on the tire sidewall.
Hope this helps..
Chris
Hope this helps..
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
