Halmfamily
Aug 16, 2015Explorer
therink wrote:
If it were me and I couldn't loosen the drain pipe enough to get flex to unseat the valve, I would likely cut the 3" drain pipe with a saw and reconnect using a 3" fernco connector.
The use of aluminum flashing between the valve seats to remove and reinstall is good advice.
This is how I replaced my 3" valve. Much easier to do if you need access in the future, loosen the two clamps and pull the pipe apart.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
