Fifth Wheel Hitch for Ram 6.4 Box
augustpilot
Would like advice on best Hitch to install in new ram 2500 diesel with 6.4 box
Do I need a slider or is box long enough for fixed Hitch. What brands work well to tow 14000 lbs. I have pulled trailers, but the fiver will be new to me. Thank all of you for your help.
2017 Rockwood 2906WS Ultra Light
2014 Dodge Ram 1500 5.7. 4x4
Firestone Air Lift 1000, Equalizer Hitch
14 REPLIES 14
cummins2014
pyoung47 wrote:
I'm always puzzled at the number of folks who have neither a sliding hitch or 4 x 4 and have never needed either. Sometimes, I wonder if these comments are not entered by tow companies and auto body/window glass people. I have both and use them frequently. The Pullrite is the standard of comparison, but it does offer some disadvantages. It's very heavy, you must couple/de-couple at a relatively straight angle, and If the truck is tilted at a different angle than the fiver, it's sometimes tough. However, I wouldn't own anything else after twelve years of towing all over the US, including Alaska, and Canada. Two wheel drive trucks are for fifties folks.
Its nice to see you mention the disadvantages to the Pullrite, some seem to deny the facts about the Superglide.
Good friend of mine finally got tired of the hassle of a Superglide , and went with the Andersen, and couldn't be happier, as am I with it .
There are just some simple facts about a slider, and there is no way getting around them like the automatic Superglide it can be a beast in more ways then one , difficulty in hitching ,unhitching, removing from truck etc. The manual slider , is just that , a manual slider, and a heavy beast also. Some don't like to hear all this ,but the Andersen solves all the convention hitch issues.
cummins2014
BobbyvCOLO wrote:
I have a Ram 2500 short bed and use the Andersen Ultimate hitch and have no issues. The nice thing is it only weight around 37 lbs and it's a piece of cake to remove and install.
No need for a slider with the Andersen, I would highly advice the OP to go with the Andersen hitch, and forget about a slider or a conventional hitch for that matter.
The deal here is once you have gone to the Andersen how more sense it makes over a conventional hitch.
blofgren
MudChucker wrote:
Worth mentioning that while I have a slider hitch, I've never had to slide it and I have the mega cab with the 5 foot box (not a ram box)
The Megacab has the 6'4" box, the same as any short box HD Ram.
OP, I have the 6'4" box as well and have a manual sliding hitch. My fiver also has the rounded front cap, and the cap of the trailer has touched the rear of the cab while backing in to tight spots with the hitch in the towing (forward) position. If I put the hitch in the rear (maneuvering) position, there is no danger of hitting the cab and the pin box easily clears the tailgate as well.
So my take is that you may not need to use the slider all of the time, but there will likely be a time when you need it. I would get a slider for those times.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
pyoung47
BobbyvCOLO
GHop
I currently have a Ram shot bed had with a slide hitch. I have been towing two different fifth wheels and have never used the slide. I believe this is due to the design of the front cap on the fifth wheels. I'm going to sell our hitch.
G.H.
2012Coleman
Me Again wrote:
The front of the 5th wheel mostly dictates if you need a slider, plus how careful you are with backing.
If you have the RAM puck or willing to install them, this is a good hitch.
https://www.youtube.com/watch?v=ebnUyxo7KX8
I have this hitch in my 2017 RAM 6.5 short bed. I need it getting into the driveway at home. It gets real close backing into my storage space, and it's pretty hard trying to keep an eye on how close the corners are getting. To slide back, I just flip the handle, squeeze the brake controller levers together so the brakes lock and slowly move forward. Only CON on this hitch is that the bottom half is heavy.
Otherwise, very easy to use, no chucking, see when you are locked in to the king pin, and you can back up at an angle - being careful of course to not hit with the lowered tailgate.
Lubricate the rails with white lithium grease.
2018 RAM 3500 Big Horn CTD
donn0128
More concern to me is going to be the OPs weights. 14K pound fiver behind a 2500? Good luck on that!
MudChucker
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
RobWNY
I have a 2017 Ram with the 6'4" box. I don't have a slider hitch. I have a new 2019 5th wheel (FR Salem Hemisphere) with a rounded and tapered nose though. The nose shape on your 5th wheel will dictate if you need a slider or not. A B&W hitch was recommended to me by a well respected member on here and what I purchased. I have no issues with it at all and recommend the B&W brand hitch as well.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
southernsky
We have a Pullrite Super Glide auto slider. Never have to think about hitting my cab.
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
MudChucker
Oh, perhaps I misread... Do you have a ram box or a ram with a short box?
I have a regular box ram... Never had to slide the hitch. This really depends on the trailer nose tho.
2017 Cougar
MudChucker
Slider alone won't do it, as you will hit the sides of the box when you turn. The only option is a regular hitch with the Reese airborne sidewinder pin box.
This will move the pivot point both up above the height of the bed and back about 30 inches while keeping the weight forward on the hitch.
Might even go so far as to say this is your only option unless someone else makes a similar hitch design.
edit: I must have been into the sauce when I typed this - I assumed you had a ram box for some reason.
2017 Cougar
Me_Again
