cummins2014
Feb 09, 2022Explorer
humblerb wrote:rhagfo wrote:
Well new truck with pucks, I would have the dealer check the install. I have a 2016 Ram 3500 with factory pucks and a Reese picture frame adapter. Mine drops in easily no issues at all. Your old issue with the rails was due to a sloppy installation. The fact that your hitch base drops easily into the frame slots, as they are made to the exact dimensions.
My issue is the same with rails and with pucks/adapter.
The tabs on the head nearest the cab are 28-7/8" apart instead of 29".
I just checked my adapter and its right on 29", they are slotted for the tabs ,but the hole is not ,so no there is no leeway for the pins. 1/8" would certainly prevent the pins from going in . Sounds like B&W did a poor job on welding on those tabs.
My Reese slider , and Andersen both fit that adapter well .
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
