nards444
Jun 18, 2013Explorer
Fifth wheel questions
Have a 2007 Challenger 5th wheel can tell you the model but its true length is the 37 foot variety, model is like a 35 something.
Anyways Been turning on the lights in one area ok fine, turn them on in another area and they quick flicker then all seem to be little dimmer.
Im going to try the remove the battery trick if everything works its not the battery and is the inverter am I correct in that, if it doesnt work its the battery.
Also the fuse panel is just as you walk in the trailer, next to is a knob that you pull in and out. Guy said something about being for the inverter, but I have pulled that thing pushed it in, doesnt ever seem to change anything, i normally leave it pushed in shich Im guessing is off.
Any insight on this.
