silverthunderro's avatar
Jan 31, 2014
fluid in slideout
When should the fluid be changed or replaced?
  • I suggest you check with the manufacturer. Checking fluid level procedure on mine is LR slides retracted, all jacks retracted and bedroom slide extended. One inch from top of reservoir. Lippert system
  • retract everything then suck out as much fluid as you can. Fill to proper level with proper fluid. I changed mine at 4 years.
  • I have a Lippert system, I was reading their information about my slide creeping out. Within the pages it said to change out the fluid, from the reservoir and fill to 1" from top. All with slides in.
  • When it has leaked out.
    The fluid is not under extreme pressure or heat so it will last many, many years.
    All slideouts 'retracted' (closed)---level should be 1" from top of reservoir.
    Just top off as needed (if needed) with the same type of fluid as recommended by your slideout mfg. Typically a tranny fluid....ATF +4
    Hydraulic System Info.
