abc40kids's avatar
abc40kids
frig issue
It was working fine the other day, went in last night and noticed the light was out. The bulb looks fine and its cold out so everything seems cold that's in the frig. I have it on shore power now and did notice that there was some water that still dripped out the outside vent like it normally does. I bought a new bulb but I'm not back yet to try it but I believe the bulb is ok. if the bulb is good, any suggestions?
  • There is a 12V auto-type fuse on the control board in the lower access (outside) panel. Usually in the left front corner of the compartment. 3Amp, sometimes 5Amp. If blown, the unit will not work on gas or shore power.
  • A small maintainer solar system is ideal for keeping a battery charged. Mine’s only 25 watts.
  • Thanks, I had the heat on two days ago as well and I know that requires a good battery.... I'll test out the heat again as soon as I get home.
