Ezbagr
Oct 02, 2013Explorer
ontariofarmer wrote:
mileshuff's way will work......and it's what I do. I doesn't matter if one side is lower than the other, when you pull the pin the leg goes to the ground. The trailer will still lift and lower the trailer straight up and down.
If it bothers you that one leg is lower than the other, just put a few more blocks under it.
This is why i have an adjustable foot-i do not need to carry blocks.
If both legs are pinned and they do not hit the ground at the same time you are TWISTING the frame-not good.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
