Piddlers's avatar
Piddlers
Front Landing Gear
Looking for advice as to which lubricant is being used on the front landing gear and how often the maintenance is being completed. I have read numerous things on the internet but would like to hear from seasoned fifth wheel owners.
Is there anything you tried that was a mistake?
Safe Travels Everyone!
  • What kind of front landing gear do you have? Mine is hydraulic and part of a 6 strut self-leveling system that I just periodically spray with silicon and wipe off.
  • Same question as above.
    I just lubed mine last night. It is the old electric screw dive type that I have to level myself. As to how often I do it, when I start blowing fuses when running the nose of the trailer up, it's time to add some fresh grease.
  • I use a dry slide type silicone spray when the legs start getting stiff. I have the manual drop leveler.
  • When I had the electric/telescoping landing gear I used a dry lube... Didn't want sand and grit attaching to the lube and binding anything...
  • I use the a dry lube on the drop legs and the electric part has grease zerks on them so I just use what ever I have in my grease gun.
  • Thank you for the information. I should have included we have The Lippert 3.0 system.
    Again, thank you for your input!
