larstech's avatar
larstech
frost control
Hi,
Ihave a montana 5th wheel iam new to rv net and have a question.
this is my first time out with this unit and the green light on the furance control is flashing one second intervel. the book says it is the frost control. What is the frost control?
  • Does your thermostat have an option for electric heat? If so, this may be the heat pump.
    Ken
  • the furance has no name on it,it is a furnance not a heat pump.It is a 05 model 3475RL
  • larstech wrote:
    Hi,
    Ours did that a few years ago,but now I have forgotten what we did to fix it. It happened while we using the air conditioner. Try pulling the 12v control fuse in your panel for a minute or so. Then put it back in. This resets the system. If I think of something else I will post it. Oh, by the way I hate this system of controlling the furnace and air conditioner.
  • It would help if you could state the year and make of the furnace. Otherwise, you may want to try to log on to the MOC (Montana Owners Forum) and let them help you out. But they will want to know Montana model and year also.
  • dont know the brand. remote thermostat no heat pump and 39 degrees
  • More information.........
    What furnace (brand/model)
    What thermostat
    Do you have 'heat pump' with A/C Unit?
    What are outside temps?
