dynk10
Jul 08, 2013Explorer
Fuel Transfer Pump Problems
I have a 2012 Fuzion 322. I used the fuel transfer station once last year. I did not store it with any fuel in it, nor did I use any gas stabilizer (kick myself for that one). I went to transfer fuel from the tank and it kept blowing the fuse. Research on the net tells me that it could be the gear has swollen because of the ethanol in the fuel. The dealer says that this is a sealed pump system and that I can't simply replace the gears. I am not sure what brand of pump is in the rig, but I think it is an ECI which is the commercial resaler for GPI. I called GPI and they said it could easily be the gears. Any suggestions or tips on what I should do next. I am out of warranty. I still have a full tank of fuel that I need to transfer out of there ASAP. I would like to transfer it to the generator holding tank and use it to extend my dry camping capabilities as I did last year, but the pump is not working as noted above. Thanks in advance.
