md_procouple's avatar
md_procouple
Furnace Not working....
Hi every one... We have a 2008 Montana and just started Full-timers now and have a problem... went to turn on the furnace last evening and No heat... Just filled the propane and have hot water, The thermostat seems to be working because the A/C is working normally. The furnace worked great last winter, So were a bit perplexed. Any Help would be appreciated.
  • Fulltimer50 wrote:
    Can you tell us what your furnace is doing?
    Yes......the more detail you can provide, the more that we may be able to help! memtb
  • More info is necessary but we can start by blowing spider webs and others out of the burner.
  • Is the fan even trying to start and do the purge before igniting? If you get the fan to run, do you hear the ignitor? Have you checked the 12 volt fuse for the furnace?
    Lots of questions before a good answer.
    Ken
  • Hi every one... Good News... after playing around with the electrical system... found a a red wire had became disconnected... tightened the crimp a little and every thing fired up as normal !! Thanks for the help
  • Don't forget that sail switches are known to go bad, too!
    Lyle
