I think I'm a bit confused here. On my Montana High Country 5er I have multiple things available.
1. Heat pump on the front air conditoner, has it's own thermostat
2. Furnace, on the same themostat as #1 above
3. Second air conditioner (only) in the back on it's own thermostat
4. Electric heated fire place (stand alone)
How it all works together:
The 2 air conditioners are ducked through the roof and ducked together. Both air air conditioners can be run at the same time and both will blow air when running alone through the entire 5er. And the front one can be on heat pump while the back one is on air conditioning. (This has actually happened a few times).
When the front thermostat is flipped to heat (the front thermostat shows the current inside temperature at that thermostat. Next it has Auto, fan low, and fan high. Next step is select air conditioning or heat.
If selecting air conditioning, the air blows out the vents in the ceiling, through the entire camper. If selecting heat, the air conditioner turns off and the furnace turns on.
The furnace is ducked under the floor and runs the entire length of the camper. It's positioned forward of center, so the rear last vent is the longest run.
Also, the furnace ducks run under the floor and are open to heat the underbelly, and about 50% of the heat goes under the floor and about 50% in the living area.
Meanwhile, it's possible to have the furnace running (fan only-low or high, auto - low or high)
But the front air conditioner / heat pump and furnace don't run at the same time.
Again, furnace is under the floor. Air conditioning through the roof.
So the question is: Is yours hooked up the same way? (all air conditioning in the roof, and all heat under the floor?) if so, then it sounds like one of your heat ducks came loose in the underbelly.
