Sprinks542's avatar
Sprinks542
Fuzion question, help needed.
Been camping in various states with our fuzion. Experiencing a outside light problem. Anyhow, does anybody know where the remote box might be mounted inside the coach. I'm hoping someone can chime in and give me a starting point to look. Heading back home tomorrow and need to resolve this.
  • Sprinks542 wrote:
    I looked in the pass through and seen a box clear in the back mounted to the floor, not sure if that's it or not. have to dig a little more and investigate. I will check above the hydraulic pump tomorrow. Thanks...
    If you have a generator, that is probably the change-over box.
  • Our remote control unit was located on the ceiling of the outside storage compartment. It is mid way across and I had to climb in there to access it from the entrance door side. This was on a Fuzion 342.
  • I looked in the pass through and seen a box clear in the back mounted to the floor, not sure if that's it or not. have to dig a little more and investigate. I will check above the hydraulic pump tomorrow. Thanks...
  • mine is mounted to the top of the top of the compartment where the slide pump and batteries are.
  • I don't have a remote. Just passing on some info that I remember when other people where looking for the remote receiver.
  • I'll take a look in the compartment. Do you know which remote your 342 has? Generation 1 or 2?
  • i have heard mounted in the front storage compartment mounted to the roof/underside of floor.
