Jmiyata
Sep 14, 2018Explorer
Genesis tire wear
I saw a post on same subject I have had same issue but mine was inner tire wear on only three wheels, Thought it was a bent axle contacted Genesis in April they pushed me off to LCI axle manufacturer. Fast forward to September trailer finally got it back. Found out not a bent axle but axles where installed backwards causing brakes to drag causing heat which blew out inner axle seals, jacking up the breaks etc. Contacted Genesis again and they said oh installed backwards its a manufacturer issue we only install axles on trailers, in which I replied exactly. Since then they have cut contact by email, called and left several messages but nothing. Now stuck with a hefty repair bill and lots of questions. Buyer be ware if you own one have your axles checked to make sure they are not mounted backwards. Have to look at magnets on backing plates to make sure they are facing the right direction. Sorry for the long post but, I’m lucky my wheel did not seize going down the road. Hope this helps someone out there reading this.
