bpounds wrote:
Thanks for this thread. Subscribing.
Pleased to see the selection of decals on eBay. Now to figure out an efficient way to remove the old ones.
I removed the decals on the front and rear caps of my Montana. The large MONTANA decals came off relatively easy with a heat gun and plastic scraper. But left on most of the adhesive. But 3M adhesive remover took that off fairly easily.
Mountains and “swooshes” were a different matter. Would break apart in very small pieces with the heat gun and scraper. Bought a 3M eraser wheel and used my strong corded gear driven 3/8 drill motor and those decals came off fairly easily. But still a lot of work as that is a lot of decal. Advantage of the eraser wheel as that a lot of the adhesive balled up with the decal leaving less adhesive to have to remove with adhesive remover.
Side decals still look good at 11 years.
