- Cummins12V98Explorer IIIMany forget this grease point on bottom of head. I also place a thin layer of regular grease on the jaws.
- John_JoeyExplorer
Tango, AE7UI wrote:
X3 for the white lithium grease on the moving points and a teflon disk on the actual fifth wheel plate..
X4 - Cummins12V98Explorer III1/8" slip plate works well with the Companion hitches. Don't forget to grease the bottom grease zerk!
- Tango__AE7UIExplorerX3 for the white lithium grease on the moving points and a teflon disk on the actual fifth wheel plate.
I also have the B&W Companion
No issues since we bought the rig in '08. - F-TROUPExplorerI use white lithium grease to lube the internals of the hitch
- ETCrockettExplorerI have a BW 20K Companion and the manual instructs me to us lithium grease on the rubber bushings the head sits on. I would recommend referring back to your hitch manual.
- HelmseyExplorerAnother fan of the lube plate for the hitch and axle grease for the pin. I keep an extra lube plate in storage as mine have a funny way of falling off when I'm not paying attention.
- MarkTwainExplorer
Cummins12V98 wrote:
What hitch????????
What grease points are you talking about????
Details DO help.
Reese 20K . The actual plate on top of the hitch that the trailer slides onto. - Cummins12V98Explorer IIIWhat hitch????????
Details DO help. - BB_TXNomadLube plate and a little grease on the pin for me also.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
