โApr-05-2014 05:45 AM
โMay-20-2014 09:13 PM
memgrove wrote:goukcats wrote:
I know several have had issues with grease seals leaking onto brakes & damaging brakes.
Found this on the Columbus RV Group FB page today. Seems the NHTSA has given Lippert and FR until May 9th to provide ALL the documentation regarding this VERY SERIOUS ISSUE!
http://www-odi.nhtsa.dot.gov/acms/cs...4008-59099.pdf
http://www-odi.nhtsa.dot.gov/acms/cs...4008-59098.pdf
http://www-odi.nhtsa.dot.gov/acms/cs...14008-6919.PDF
If you've had any issues & haven't filed a compliant with the NHTSA, it's not too late! Please go to their website and file, even if you have had the repairs done, it is imperative that we get ALL the information out there to hopefully force a recall and prevent someone from getting seriously injured and/or worse, killed. THANKS!
I know this is a few weeks old But we were just denied warranty help from Dutchmen/ Keystone AND our extended warranty coverage by Cornerstone.... I need help getting these links to the documents to work. I have tried using Google to search and I have tried to get the search on the nhtsa site to find them and I just don't seem to have any luck. Any help would be appreciated, thank you
โMay-20-2014 09:00 PM
โMay-20-2014 07:57 PM
โMay-20-2014 07:28 PM
โApr-21-2014 12:05 PM
โApr-08-2014 11:05 AM
B.O. Plenty wrote:allimax wrote:The grease that you pump in goes into the backside of the rear bearing. Between the bearing and the seal. It then goes through the bearing and into the cavity between the fron and rear bearings. From there it goes through the front bearing and out the cap next to the zerk. In order for this to work correctly it has to fill the cavity between the bearings. I prefer to do mine the old fashioned way every couple years. I could probably even stretch it to once every 4-5 years. I've never found that my bearings were anywhere close to dry.
Using the fittings is a time-saver, but what a mess. I did mine today the old-fashioned way and the entire hub between inner and outer bearings was full of grease. My brakes were clean, though.
B.O.
โApr-08-2014 09:44 AM
โApr-08-2014 01:57 AM
โApr-06-2014 08:23 PM
โApr-06-2014 02:13 PM
โApr-06-2014 06:18 AM
โApr-05-2014 05:25 PM
โApr-05-2014 01:08 PM
โApr-05-2014 08:20 AM
