โMar-24-2020 11:33 AM
โMar-25-2020 05:08 AM
โMar-24-2020 07:55 PM
B.O. Plenty wrote:rconkin wrote:Whoa! They look just like the standard electric leveling jacks that many RVs have. They have a screw jack inside just like those. Might be worth comparing them.B.O. Plenty wrote:
Considering most of the weight is on the wheels, the actual load on those front jacks isn't that high. Thousands of trailers have them and yes they do require some maintenance. They don't cost a lot and are easy to change.
B.O.
This is their auto leveling system where the two front legs work independently of each other. Depending on how level the site is, they will take some weight of off the tires sometimes. I don't consider $450.00 per legs cheap and that was the best price I could find on them. I had to buy the entire assembly which includes motor and gearbox. I don't trust them now and will return to putting boards under the tires to level side to side before hitting the auto level. Kind of defeats the purpose of having the auto level. There is nowhere to get grease in them without taking them off and disassembling them. That's why I'm thinking of drilling the hole and at least getting some grease on the gear above the leg that extends.
B.O.
โMar-24-2020 07:33 PM
B.O.
โMar-24-2020 04:06 PM
Super_Dave wrote:Birdnst wrote:
I cannot resist Dave did you not read th op
I did but I guess it didnโt translate in my question. What was the gear made of?
โMar-24-2020 03:58 PM
Super_Dave wrote:
What is the material clogging the screw leg?
โMar-24-2020 03:56 PM
garyp4951 wrote:
Did you run them way out every time you set up, and not drop the inner legs? Just curious, but I have seen this posted before about not being able to grease them too.
โMar-24-2020 03:52 PM
B.O.
โMar-24-2020 03:29 PM
Lynnmor wrote:It's definitely not steel and your probably right guessing pot metal. That's what I would guess.
The nut looks like cast pot metal, can you determine what it is made of?
โMar-24-2020 02:24 PM
โMar-24-2020 02:23 PM
โMar-24-2020 02:18 PM
โMar-24-2020 02:13 PM
โMar-24-2020 01:40 PM
โMar-24-2020 12:17 PM
