Water-Bug's avatar
Water-Bug
May 28, 2015
Hitch Maintainance
Ok, so four years ago we bought our first 5er and had the dealer install the slider hitch. Bought a Teflon disc and forgot about maintainance. Two years later, had the dealer move the hitch to a new truck. Had the RV dealer do it because he would adjust the pinbox for correct leveling and truck dealer wouldn't mess with 5er. Last week, I had to remove the hitch to haul something in the truck. I removed the hitch assembly from it's cradle to cut the hitch weight in half. That is when I noticed the dry rust on the cradle and pivot pins of the hitch. Not good. It appears that there has NEVER been any lubrication on the pivot pins or cradle. Those pins support the entire pin weight and we're dry metal on metal. I lathered them up with wheel bearing grease. While at it, I extended the slider for the first time in 4 years, and gave every thing a liberal shot of white lithium grease. (It wasn't initially easy to extend). I wonder how many people think that the Teflon disc is a solve all for hitch maintainance.
  • Maintenance on a 4 year old hitch is the responsibility of the owner not the RV dealer. Looks like the OP realizes that part now.
    I've owned three different 5th wheel hitch brands for RVs and several of SAF Hollands types on my hauling rigs. Always broke them down for a full lube before going into service and then annually.
  • A new hitch comes with a service manual. In it, it advises to re-Torque the hardware(with the stated torque) and to lube the pivot points. And slide rails if you have a slider.
  • I also check the torque on the bolts once a year. Rail and frame bolts
  • agesilaus wrote:
    I give the hitch a pre-season lube every year. Just did it as a matter of fact 10 days ago.
    I do also. Before taking the first trip I lube the hitch up, slop some grease on the trailer pin.
  • You cant listen to most of those guys. They blow their way through many of the repairs because most people aren't going to ever check the work and they often dont know what to look for anyway. Yes, I often mark my tires before I take it in for a rotation.
  • We just got back from Branson literally 2 hrs ago. Had to use the slider for the first time in quite awhile to get into a tight camp site. It didn't want to slide, I did get it to move but it wasn't easy. I have an older Reese slider that slides on some pads that are kind of like teflon. Gave the rails a shot of lube that you use on your slide outs. Works great. I also give the jaws and pins a good shot of lithium grease every spring.
  • I spray lithium grease on my jaws each trip and shoot grease in the zeros once a year. When I had a slider I sprayed the rails once I think and you are correct they don't move easy if not lubed.
  • I give the hitch a pre-season lube every year. Just did it as a matter of fact 10 days ago.
