May-01-2016 05:46 PM
May-05-2016 06:31 AM
ol Bombero-JC wrote:clotus wrote:
We don't have a TV, so no problem for us
No TV ???
How do you get it where you want to go - without a TV?
Oh - OK I get it - you must have a Motorhome.
May-04-2016 06:01 PM
fla-gypsy wrote:
Only you can determine what will work for your circumstances.
Just think it through carefully
May-04-2016 05:47 PM
May-04-2016 11:20 AM
Earl E wrote:
OK here is a little bit of an alternative view. We LOVE the rear entrance in a smaller RV. We had a Arctic Fox 32' fiver that we full-timed in and found it very comfortable. The rear entrance makes a wonderfully large floor space as well as a great view out the back window. In fact, after we got off the road we bought a smaller pull-trailer that had a rear kitchen and just took a loss and traded it in for another small pull-trailer with the rear entrance and chairs in the rear. We love it. True, the door is often in the rocks or grass because of the way many parks are designed but an outside door mat took care of that. The only problem I see with the one you are looking at is the closet space in the bedroom. That may not be enough for full-timing. You need space for four seasons of clothes, even if you are chasing the sun. There is a reason for the popularity of this design--it maximizes the space.
May-02-2016 09:33 PM
May-02-2016 08:48 PM
May-02-2016 08:35 PM
May-02-2016 07:55 PM
janegowest wrote:I'll answer because your question is generic. Ours is an '09 35 fd3, we special ordered for the walk through bath and w/d prep. We liked the double door separation between bed and living for the late or early risers. We also ordered that the island be movable, as we store it in front of the table when on the road, so our kitchen and living is useable without opening slides for a lunch stop or even an overnight.travelnutz wrote:
A few other things I noticed were that it's a mid entry, has a fireplace in clear view, theater seating directly at the front of the tv, another couch at a good angle to the popup tv or maybe even replace that couch with one or two swivel rockers or recliners, has a walk in nice closet in the bedroom, has a built in seat in the large shower and that's very cool, if the 8' fridge is selected leaves another pantry too.
The more I study the floor plan, the more smart things I see for either full time living or traveling/RV'ing for short period or long periods. Add in that it has a large freshwater tank and a large gray water tank. and a good sized black water tank too.
Actually, because of the corner sink, there's a lot of countertop behind it for things like a toaster and coffee maker etc to remain at which will be close to use/access but yet not in the way when making meals and don't have to be constantly removed. We know how excellent this is because we had the same in our 36' Carriage 5th wheel and have in our 29' Carriage Carrilite 5'er and simply love it. Wife says, "just like at home"!
Very easily towed behind out present SRW Duramax truck too, dang!
I better stop looking because if I do and keep seeing more goodies and positives, we just may have to order one! The dangers of peeping!
What models were your carriages?
May-02-2016 07:29 PM
May-02-2016 07:12 PM
May-02-2016 05:57 PM
travelnutz wrote:
rhagfo,
I have to apologize for not finishing my post correctly as to the actual rear kitchen layout of the Jayco Eagle 293 5th wheel quite similar to your 5th wheel layout. Got interrupted while writing and didn't look back at the wording I had written.
The Jayco Eagle 293rkds has a about a 2' wide walk in doored large pantry where your fridge is and they'd moved the fridge over to the passenger side wall toward the front of the RV in the kitchen and close to the range/oven with the microwave above so all have full access with the slide in. This keeps the kitchen counter top space still adequate. Also allows the option to have a double side by side door 12 cu ft fridge if desired instead of just the 8cu ft standard fridge. This can be very important for fulltime living as an 8' will seem very small since it's only a fraction of size of even a small norm basic home AC fridge. Also, the large pantry is great when and for fulltime living and provides an additional storage area when short term RV'ing too. Versatility alive and well! Yes, also has room for a W/D in the model too all in 34'5" pin to rear bumper. Me thinks somebody did their homework!
May-02-2016 05:50 PM
Michelle.S wrote:
We had a rear entry Montana, and had an issue with the steps hanging down to far that we dragged them several times getting in and out of fuel stations. Once so bad they had to be removed and a sledge hammer used to bend them back in useable shape.
May-02-2016 05:20 PM
May-02-2016 03:10 PM
travelnutz wrote:
rhagfo,
You must be late to the party of Jane's many wants, needs, questions, and thoughts.
Jane has over half a dozen threads running for a couple weeks now and has repeatedly said she want's a W/D in the RV and a lot of other things that are making it hard to find anything she's happy with. She is completely new to owning, hauling, living, traveling with and/or in a RV. All have and will fall short in more than one or even a lot more of her desires. Unfortunately, her stated budget max is also of no help either. Go read her threads.
Moving the fridge a couple feet doesn't cut into much of the counter space if you locate the sink differently and make the "L" leg a little longer.
Jane also wants to RV around the country with the RV after they are finished repairing their home and that makes various features much more important for easy access along with length. She wants to kill 2 birds with the same stone and it's not that easy!
