hopeisnotastrat
Jan 09, 2016Explorer
golf_bears wrote:
Any one of those trucks will pull those RVs. That is not the problem. The real issues to be concerned about are:
1--- Will the TV rear axle carry the load? What's the TV rear axle rating.
2--- Will the TV tires carry the load? What are they rated for?
3--- Will the truck stop the load?
As suggested, you can change the gear ratio and/or go to a dually.
Personally, I would get a dually with at least a 4.1 gear ratio.
The FifthWheelSt calculator doesn't account for gear ratio. I was always told it impacted your towing, so I'm not sure how to determine how much more (or less) I tow going from the standard 3.42 gear ratio to the 4.1 gear ratio.
Also, how do you determine if the axle will carry the load and if the tires will carry the load?
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
