laknox
Jan 10, 2016Nomad
golf_bears wrote:
Any one of those trucks will pull those RVs. That is not the problem. The real issues to be concerned about are:
1--- Will the TV rear axle carry the load? What's the TV rear axle rating.
2--- Will the TV tires carry the load? What are they rated for?
3--- Will the truck stop the load?
As suggested, you can change the gear ratio and/or go to a dually.
Personally, I would get a dually with at least a 4.1 gear ratio.
Like many RVers, you get a TV with more capacity than you need to start with because down the road Ma-Ma most likely will want a bigger RV.
As your user name implies, "hopeisnotastrategy", get it right the first time!!!!
#3 is not a real issue. The truck stops itself and the trailer stops =itself=. Only in an emergency do you have to worry about the truck stopping a trailer by itself. Even a semi doesn't have the braking power to quickly stop a max load. Yes, in dry, flat conditions, you'll stop it, but on a downhill or in an emergency stop, you're going to jackknife, almost certainly; roll in a worst case. Yes a larger truck would be better, a dually ideal.
Lyle
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
