peaeye1's avatar
peaeye1
humming/ buzzing noise
There is a humming/ buzzing sound coming from the transfer switch.The unit is prepped for a generator, but one is not installed.It has been making this noise for at least a couple of months.I have pulled the cover on the switch box and everything "looks" ok. The box is not hot to the touch and no smells like wiring is getting too hot.This is on a winnebago 5th wheel using 50 amp service.Everything electrical works fine on the trailer.The sound can't be heard inside the unit, only when accessing the basement area.
I thought I would run this by the folks on here before calling the dealer tomorrow.
  • In my 21 years as an industrial electrician with experience with the same contactors as these transfere sw's, most of the time they were dirty or the armature was rusty so that the two parts would not come completely together. The dirt and rust impeded the flow of the magnetic field between the two parts causing them to hum/chatter. The fix was a complete disassembly and a good cleaning.
  • The buzz is caused by the two pieces of metal that are pulled together by the magnetic coil and pull the contacts together. Generally dust/dirt keeping them from seating against each other totally. As said, blow the relay out with compressed air or, if you are mechanically inclined, dismantle it and clean it. If it's older, you'll find the surfaces get a beat-up look and this can be fixed by smoothing them off by putting coarse sandpaper on a flat surface and rubbing the part on it. Takes some elbow grease as the surfaces 'work harden' from the banging together. Or...you could just buy a new relay!
  • Mine has been buzzing since brand new. I called the MFG. and they said this was normal.
    I also have a generator prep with no generator.
  • Sometimes the relay coils will hum. Not a big deal as long as that is what is making the noise. Disconnect all power and blow ATS out with compressed air. Seems to help quiet mine down when it starts to hum. If it REALLY bothers you, you can replace the relays with ones that are designed to not hum, but now you are talking several hundred dollars and might as well just buy a new ATS with the no-hum relays.
  • No big deal. Could be just dust. Loose connection. Since you checked it and not hot or burning smell I wouldn't be so fast to shut it down or buy a new ATS. If it makes you feel better. Mines been humming on and off for years. Got use to it.
  • Old-Biscuit wrote:
    Either wiring terminals are loose
    OR
    Relay contacts are worn....not making FULL surface contact.
    They are arching and will fail
    Thanks, I will turn off power to the unit and tighten connectors. This unit is less than a year old.Odds are loose connections.
  • Either wiring terminals are loose
    OR
  • My humming buzzing was a bad converter. You could barely hear it but the sound was there in the coach. Took me awhile to track it down. Since the converter only turns on when needed.
    When we opened the old converter one capacitor was shot. Almost literally, it looked like someone shot it with a 22!
    And BTW with only one capacitor working it managed to totally fry my coach battery by emitting too much voltage. Go figure.
