- GoostoffExplorerAbout the only thing you can really do is look things over and determine in your own mind if it is in god enough shape for your needs. If an elderly couple had it and kept everything spotless and used it every day you would probably be better off with it over one that some baby momma and her crack head boyfreind had and only used 3 times a year spilling beer all over and the dogs crapping in the corner and not getting cleaned up.
- VeebyesExplorer IIIn the boating industry it is not uncommon to get a survey prior to purchase.
Of course these surveys are not cheap & are not often done on small boats selling for under say $50,000. I would think that an RV surveyors time is going to cost in the region of what a marine surveyor time would be. Maybe abit less but still, the time adds up, what with the report that is drawn up as well.
For boats having a used value of $100,000, $200,000 & up the survey is a small part of the cost & well worth it in boats with complex systems to check, not just the engine.
RVs, tow behinds especially, are relatively simple things. Even somebody with little knowledge, & armed with a checklist, should be able to do a decent survey on their own or with a knowledgeable friend. - EA_WilliamsExplorerJust ask the Camping World sales rep, I'm sure he will tell you it was only driven to picnics on Sundays.
- dedmistonModeratorCheck the hours on the generator.
- CdashExplorerHere are some things I'd look at that could help, may sound strange, but I can see a correlation:
Look at the pivot points on the steps, any wear or rust?
Check the toilet - any movement? Does it wiggle?
Suspension - if you can, look at the shackles. Although the wear would be hidden behind the washer nuts, compare how much of the shackle is visible from the nut to the end of shackle. Compare top to bottom. Any difference is the shackle hole ovaling out. I had to replace mine at about 15,000 miles.
Pin box - how does the pin look? Wear marks from the jaws that go beyond just paint scratches?
Check the cabinet doors that would seem to get most use (pantry, where dishes would go, medicine cabinet) are the looser than others?
Couch cushions and mattresses - don't forget to flip them over.
Just some thoughts. - ol_Bombero-JCExplorer
hitdrd wrote:
We are buying a 2006 fifth wheel and would like to know if theres any way to figure out how much it has been used. Anyone know?
Enter "PDI" in search. (current 12 months & archives).
Several excellent check lists have been posted over the years which would apply to a new or old rig.
If you don't feel confident in your ability - hire an inspector when you have narrowed your choice/s.
~ - hitdrdExplorerbob krogstie where's the hub odometer located? does dvery 5 th have one?
BobKrogstie wrote:
Check the hub odometer :B
For awhile I was looking for one of those for the trailer. Gave up.
I have all of my routes saved on MS Streets & Trips. Those are mostly just the trailer miles so getting a fairly close total is not hard to do. - Mile_HighExplorerI have found there are also those that buy them and use them full time but don't even own a tow vehicle, so very little road time, or those that tow them all over the country but only a few months a year, and the rest of the time is sits in storage, or even in a garage.
Many variables. I would have to agree that the one that is used, is probably maintained better.
My truck has an odometer that counts miles on each trailer I plug into it, and can even tell which trailer is being plugged in. Kind of cool. - ACZLExplorerFabric still in good shape?, Wear/rubs marks on walls, floors, furniture from slides? Interior walls damaged? Is interior filthy? Walls dingy looking. Carpet look like it's seen it's better days? Any urine smell? Outside walls full of scratches/dings? Rust on frame? Basement/front compartment relatively clean? Just my thoughts.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
